D16Z6 Engine Build
D16Z6 Engine Build
I posted this earlier in the new member's section so I'll just repost it here which seems more appropriate. I've been searching posts on this site for a good couple months now and I get sidetracked reading interesting posts, but have not been able to find an answer to my questions. There's sure to be plenty more and I'll be creating a 'what I've done' thread so that I can keep updating as I go along' For now, I'm at the buildup stage and am running into questions that my machine shop guy doesn't know. No offense to him, but I need to find an import shop, and honestly he did warn me that his shop works mostly on V-8's and American engines...I didn't think it mattered much. So...without further tangents, the repost:
She's a sweet 1993 EX with a D16Z6. Betty is what I think I used to call her. Anyhow, she's been in the family for quite some time now, 14 years or so. The only viable picture I could find though is the one posted in my garage. Certainly there will be more to follow. It's been bounced around between me and my siblings until I finally purchased it a year or two ago. So, it's my baby and I plan on nursing her back to health.
I began having coolant issues and decided action was necessary instead of topping off the radiator every couple of days. Once I figure out a good place to publicly store my pictures, I will post links to all the photos of my engine build...Got some goodies so far.
I'm still unsure of where it is appropriate to post my questions, so i'm just going to post the first ones I have in this introduction.
I have taken the engine out of the car and have had machine work done to the head and block. I am in the process of reconstruction. Be sure to check out my latest posting on youtube:
http://www.youtube.com/watch?v=0t-LklBlsW4
http://www.youtube.com/watch?v=hp_djePxxJo
Just a neat little vid of me breaking down the engine...for the second time. I need to combine the videos, unfortunately the camera batteries died because I forgot to plug it in. So, this was me breaking the engine back down when I realized that I didn't want to use my original crankshaft.
And so finally for the first question. If there was no machine work done to the crank or block bearing surfaces, do I need to buy individually sized bearings for the crank and rods? The block is stamped with the main bearing sizes, the crank is stamped with main and rod bearing sizes and the rods are stamped with the journal sizes? I purchased standard sized bearings (recommended by my machinist after measuring everything), when I bought my pistons. The rods are the original stock rods. It seems after pouring through the forums that this is not a question people have asked. I guess if you're trying to build the engine you should already know this?
And for the second question. When putting the timing gear onto the crankshaft, should there be any play on the shaft?
http://www.youtube.com/watch?v=-jIvzH8USmw
I bought a second crankshaft because the first had keyway and bolt thread issues, but both cranks had this wobble. Is this normal. I have also purchased a new balancer/pulley and timing gear, but have not checked the new gear on the new crank. I purchased the gear with the balancer because I figured perhaps the old one is worn? So, what gives?
turbo speeder
01-28-2009 03:57 PM
SovXietday
02-12-2007 11:55 PM
