electrical problems
Old 12-26-2007, 10:10 PM
snow_boarder1616's Avatar
Default electrical problems
Hey guys. I have a problem and if anyone knows what it could be let me know please. I have a 97 civic lx project car. My cars electrical is pulsing so I thought it was alternator or battery so I changed them. Well it still does it and the new battery dies fast. I don't know whatss wrong so maybe u can give me some help
Old 12-26-2007, 10:16 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: electrical problems
Get them tested at Batteries Plus, Autozone, Advanced Auto Parts, NAPA, or local auto shop.
Old 12-26-2007, 10:38 PM
Sounds like the alternator may still be faulty.
Is the alternator belt loose or slipping? Does the charging light (battery symbol) on the gauge panel turn ON? As danomatic93 says, you should have your alternator and battery tested at an auto parts store.
Another possibility is that you have an electrical short or a bad ground. Regarding the latter, check for corrosion on your battery terminals and the connection of the negative battery cable to the body ground. Clean any corrosion on terminals to ensure good electrical contact.
Old 12-27-2007, 06:41 AM
I think if (for whatever reason) you're not getting power to the "I" wire on the alternator, it will do that. That wire should have battery voltage whenever the key is on.
Old 12-28-2007, 07:38 PM
Overurhead360's Avatar
I thnk i am having this same problem in my 98, I think a ground to something has a bad connection, is it bad to have liek 4 things grounded to the same bolt?
fierychick
01-29-2009 11:23 AM
drewbhot
02-20-2006 04:13 PM
RSXt3
11-05-2005 01:55 PM
abe_frohman
09-17-2005 08:05 AM
lihin
06-30-2005 05:29 PM
Quick Reply: electrical problems
