gas mileage gone bad
Old 07-25-2006, 09:51 PM
dee1's Avatar
Default gas mileage gone bad
wuz up yall got a 99 ex a/t getting about 22 mpg whats wrong
Old 07-26-2006, 02:21 AM
Mr Mobsta Man's Avatar
Default RE: gas mileage gone bad
air filter is probably dirty or your running the a/c?
Old 07-26-2006, 09:33 AM
I got about 330 miles on my '96 EX auto with the air on the whole time. Highway miles up and down some mountains. Does this sound about right?
Old 07-26-2006, 10:23 AM
Check your tire pressures, too.
When was the last time you changed your oil?
Auto or manual transmission?
Old 07-26-2006, 02:46 PM
pWnEdU's Avatar
Tune it up. Air filter, fuel filter, plug, wires, cap, rotor etc. Run some sea foam through it. Also make sure your tire pressures are good.
Old 07-26-2006, 02:52 PM
hey man dont feel bad i got 98 ex tht only gets 17.5 mpg. [sm=rolleyes.gif]y?[sm=rolleyes.gif] i dont noe but its not a problem to me since its only 30 bucks for a near full tank
Old 07-26-2006, 07:21 PM
dee1's Avatar
that dont sound to bad to me since i only get about 200
Old 07-27-2006, 03:53 AM
Well I have a '98 1.4 Civic and I get about 140 miles to 20 litres of juice. That cannot be good for a standard car w/CAI and a De-cat!
My dad has told me to buy a new O2 Sensor, as when they get older they deteriorate and struggle to send the correct voltage to the ECU. Apparently when he bought a BMW 320i coupe a few years back, he was getting really poor MPG (less than 20mpg). It turned out to be his O2 sensor. Mine does look pretty crappy so I think I'll give it a go. Only £20 too, so I have little to lose. Gotta be worth a try.
=chris=
Old 07-27-2006, 08:24 AM
gwl's Avatar
gwl
gwl is offline
I get about 34 mpg with my AC on about more than half the time. If I don't run my AC, its around 38-40. I have 97 HX mt with a quarter of a millions miles.
Old 07-27-2006, 10:42 AM
Along with what everyone has said here (tires, filters, sensors, etc), here's a couple of things to think about:
1. How does it run? Does it idle rough? Do you suddenly loose power while accelerating? Does it hesitate or cut out at any time? Is there any kind of smoke coming out the tailpipe (white, gray, black)? All of these are clues that can help you troubleshoot the problem.
2. When you troubleshoot the problem, start from the outside and work your way in, that is, start with the easy external stuff and then work your way into the engine to the more complex answers. Example: start with tires, air filter, check what's coming out your tailpipe, their all easy, then move into more complex possibilities. Only change one thing at a time and then see what happens.
Or, you could just get someone to plug a computer into your OBD port, if you have one......
Good luck!
Gen5unknown
26
01-09-2008 10:00 PM
Live_4it
03-13-2007 04:57 PM
civic x
05-16-2006 02:16 PM
96civicexer
01-17-2006 01:31 PM
red_sleeper
21
01-13-2005 08:58 PM
Quick Reply: gas mileage gone bad
