Header sits really low what can i do?
on my car its lowered by a good 3 inches, my header is only 2inchs off the ground, i am afraid of rippin it off, so what can i do to protect it from gettin pushed up in when i scrape? i dont wanna lift the car any suggestions?
how much would have to lift the front end? .50 of an inch? would a skid plate hold still even if it gets hit, i just dont want the header to get pushed up, would an aftermarket skid plate protect it?
Do you have coilovers? If yes, then remove the wheel, loosen the collar on the coilover and twist the coilover to raise the vehicle. Otherwise, buy new springs. We need to know what kind of suspension you currently have.
I've never heard of an aftermarket skid plate for a civic. You can find them for trucks and jeeps... I suppose you could modify one of them. But honestly, thats stupid.
Have someone who's good with welding lop about an inch or two out of your header and weld it back together. Thats what alotta people do when doing an H2B swap if they don't have a h2b specific header.
edit- this is assuming you have some room between the header and the oil pan, which most headers do.
yeah i have lowering springs all around, but my front are adjustable, i just dont want to lift my car .50 or .75 of an inch and make it look dumb, you can see how high my car is just look in my garage pics
Shandles has a good point, check for a gap between the header and the oil pan. If there's space there, there is room to get it higher off the ground by modifying the header or using a different header, until the header is almost touching the pan.
Skid plate FTW. Go to the Home Depot, buy yourself a piece of sheet metal, cut it with a plasma torch to fit, then bolt it up custom. If you bottom out, you'll put on a light show with all the sparks that will fly.
Really, though. Raise it back up. Put some 16s on it. Call it good enough.
im gonna do a skid plate, i just gotta drive careful, but now i have to repair my damage on my front end, and btw some website called honda india..... something they are 3rd party, they are taking what we are saying and putting it up on there website info and all, just thought id let ya know
