rear disk conversion on 93 LX
Old 04-07-2011, 08:08 AM
Vartok's Avatar
Default rear disk conversion on 93 LX
I was browsing through the marketplace on H-T and came across someone selling "rear disk conversion" out off an 01 integera.... i txted them and they said that they think it will only work for the 2 door civics (so im guessing its a 2 door integera) but ive never seen anything saying one way or another.... So is the trailing arm different between the two?
Old 04-07-2011, 08:44 AM
I thought all trailing arms 88-00 were the same. Some had ABS, some didn't.
Old 04-07-2011, 09:15 AM
I believe Hobo is correct.
Honda Parts at HondaPartsDeals.com: Honda Accessory, Honda Car Parts, Honda Auto Parts, Honda Accord Parts
Look up a coupe and a sedan, find the trailing arm part numbers and compare. If the first 5 numbers are the same, you can assume that they are the same part I think.
Research what else you need before jumping into it. You need more than just the trailing arms.
Old 04-07-2011, 09:25 AM
Vartok's Avatar
Ive been having trouble finding a definite yes or no on rather i need a new MC, booster, and prop valve
Old 04-07-2011, 01:01 PM
Vartok's Avatar
also, found this... someone selling both front and back... would this be worth it?
Im fairly sure i would need the mc and booster when doing both... not sure about the prop valve though.... just looking for advice/suggestions at this point
colby_666
10-08-2007 09:57 PM
TeamExodusPres
02-05-2007 05:29 PM
TeamExodusPres
02-05-2007 05:28 PM
ahhsimon
06-14-2006 09:52 AM
mill$civic
12-05-2005 12:40 PM
Quick Reply: rear disk conversion on 93 LX
