02 Honda Civic starting problem?!??!
Old 05-02-2015, 03:07 PM
Soviek's Avatar
Default 02 Honda Civic starting problem?!??!
Immobilizer key symbol doesn't turn on like it did before replaced Ecu and still car won't start it only cranks HELP!!!
Old 05-02-2015, 04:10 PM
itburnswhenIP's Avatar
did you have honda re-program the keys to the new ecu ???
Old 05-02-2015, 06:25 PM
Soviek's Avatar
I didn't reprogram it but with both computers the green key light doesn't kick on
Old 05-02-2015, 08:54 PM
mc00's Avatar
I had this happen to me last year i went to junk yard removed the immobilizer and have it reprogram by car lock smith, all it is ur vin number program to the key and immobilizer device this thing tend to go bad on this car...
Old 05-03-2015, 05:18 AM
Have you checked the key itself and the receiver module near the keyhole? The receiver picks up the signal from the key and sends it to the ECU. I do not think it needs to be programmed to match the key, it just passes any code it receives to the ECU.
Or maybe it is not being immobilized but something else is broken. Look for the CEL to turn on and back off when you turn key on but don't crank, this is a sign that the ECU is booting up and running and I think it will happen even if key is not recognized.
djt
06-21-2008 07:48 AM
chikna
15
03-03-2008 10:22 PM
Rescue56
02-25-2008 05:06 PM
totenkopf
05-31-2007 03:36 PM
kauaigal
03-03-2006 11:33 PM
Quick Reply: 02 Honda Civic starting problem?!??!
