steering wheel vibrations
Old Apr 27, 2011 | 06:42 PM
funnymonkey24's Avatar
Default steering wheel vibrations
Ok when I brake in my eg from any speed, but it is more noticable from highway speed the dyeing wheel will vibrate I know its not warped rotors either because there is absolutely no vibration in the brake pedal.
I am almost positive it is a worn bushing but iam not sure which one it is.
Any help is appreciated
Old Apr 28, 2011 | 11:49 PM
sillysef's Avatar
it could be your tie rods that are going bad..
Old Apr 29, 2011 | 03:32 AM
Mecca8383's Avatar
if it is a bushing you need to take off both wheels & check out every bushing you can see, sometimes a bushing can be completely gone and you won't even know a bushing goes there so check both sides of the front to compare.
Old Apr 29, 2011 | 06:03 AM
mundy5's Avatar
Why do you automatically assume that it is not warped rotors? It can cause significant vibration at the steering wheel as well. My bet is the warped rotors as it is the easiest to check.
Old Apr 29, 2011 | 07:14 AM
I would also say it's a warped rotor. They have to be really bad before you feel it in the brake pedal.
jpnolan
Apr 14, 2009 11:11 AM
bakertime
13
Mar 13, 2007 09:32 PM
green98lxsedan
Jan 10, 2005 09:49 PM
duke
Dec 21, 2004 08:32 PM
nwhite82
Dec 19, 2004 01:04 AM
