copression testing
Old 08-17-2004, 10:02 PM
la tuya's Avatar
Default copression testing
hey i am new to the scene. in order to take the compression on a b16 you have to, take the spark plug out put the tester in and what else do i have to do?and also what #'s are good and bad.thanks
Old 08-18-2004, 12:09 AM
sacicons's Avatar
Default RE: copression testing
take out the fuel pump fuse (underhood fuse box) and unplug the big wire connector on the back of the distributor. then cycle the motor through seven compressions and note the reading. mine is around 205 in all four. they should all be close to each other. also, take out all four plugs before you start. if any are low then put a couple of drops of motor oil in the hole, then retest. if it is a lot better, then its the piston rings, if not, then its probably the valves. and thinking back, i see it might not be in the car yet. in that case i have no idea. sorry.
Old 08-18-2004, 01:27 AM
la tuya's Avatar
thanks
Old 08-19-2004, 11:43 AM
another general tip is to give it full throttle (not running though!) to let the maximum air in.
Old 08-19-2004, 01:52 PM
sacicons's Avatar
thats right, thank you. lock open the throttle with a pair of vise grips or something.
jwsimons
02-04-2006 12:09 AM
sacicons
12-18-2005 08:21 AM
niteryder
01-23-2005 06:55 PM
Quick Reply: copression testing
