testing an ecu, is it possible?
Old Feb 3, 2006 | 04:32 AM
jwsimons's Avatar
Default testing an ecu, is it possible?
i have asked a couple places, they say no! you cant bench test an ecu. the ecu is the only thing holding me up, at this point. when i plug everything in, hook up my battery, what i do get is that all my trouble lights in the gauge cluster light up, with no key in the ignition!!! i cant find anything that i have wired incorrectly. and the ecu itself never gives any flash code at all. so whaddya guys think, bad ecu? or keep double checking my wiring? or anybody gat a trouble shooting suggestion? this is real important because as of sunday i became a saturn owner /driver. but the car is boring to drive...
Old Feb 3, 2006 | 06:10 AM
Street Sniper's Avatar
Default RE: testing an ecu, is it possible?
You dont know anyone else with a Civic? Swap out into a known good car and see if it works. My guess would be wiring though.
Old Feb 3, 2006 | 10:40 PM
jwsimons's Avatar
actually, ive got two other ecu's but they are from sohc non v-tec. one from a dpfi and one from an mpfi. i'll try the mpfi and see if the same problem occurs. dont know any body else with a v-tec civic, but ill keep my eyes open..... i'll be back in a few..minutes?
Old Feb 4, 2006 | 12:09 AM
jwsimons's Avatar
i took the ecu that was in my si, hooked it all up, connected the battery, and no lights. i turned on the ignition and then all the check lights came on, like they should. so the other ecu must be bad?
Civic maniac
Nov 30, 2008 01:58 AM
geetarz
17
Jul 2, 2008 04:21 AM
asdfbrendan
Nov 7, 2007 05:53 AM
hewittm
Jul 10, 2006 05:07 PM
niteryder
Jan 23, 2005 06:55 PM
