Engine "sputters" at idle but not during acceleration
Old 10-30-2007, 09:48 AM
Garon's Avatar
Default Engine "sputters" at idle but not during acceleration
Hi All,
I have a 95 Civic EX with 138,000 miles. It was bought new and always maintained well.
My engine just began"sputtering" when at idle as if it wants to die. If you push the gas at idle, or accelerate while driving, the erratic idling goes away. This happened all of the sudden with no precurser of what could have caused it. Everything else is working fine on the engine. The plugs and plug wires are fairly new, the fuel filter and air filter are clean, no overheating issues, no coolant loss (head gasket fine), and the fuel injectors were recently serviced (cleaned).
Any ideas? I have several, but most of my theories don't work since the problem goes away at acceleration.
Thanks in advance!
Old 10-30-2007, 10:09 AM
bp4131017's Avatar
Default RE: Engine "sputters" at idle but not during acceleration
The first thing i thought of was oxygen sensor.
That's how the engine runs when the oxygen sensor broke/is faulty
another possibility is your ignition timing
if it's off it causes a sputter, but you would usually have to do something to cause it to not be timed correctly. Unless your bolts to the distributor cap aren't very tight
Old 10-30-2007, 10:33 AM
Garon's Avatar
If the oxygen sensor or ignition timing was not working properly, would you not detect this when the car is moving (when gas pedal is engaged)?
Old 10-30-2007, 10:54 AM
Idle air control valve. As it's name suggests, it is only necessary when idling.
Though checking the timing is also a good idea.
Is your check engine light on? A bad oxygen sensor will almost always be detected and turn the CEL on.
Old 10-30-2007, 11:59 AM
Garon's Avatar
The "check engine light" is not on.
Old 10-30-2007, 12:10 PM
Take your IACV off and clean out the air passage with spray carb/throttle body cleaner. It's mounted on the back of the throttle body with two bolts. You don't have to undo the water hoses.
Old 10-30-2007, 12:26 PM
enigma34's Avatar
could be oxygen sensor,i just got a new one for my civic. you said you put new spark plugs in, how close to when your car started ackting up? it could be the wrong type of spark plugs. i know that my civic needs a a special type.
Old 10-30-2007, 01:42 PM
Garon's Avatar
New plugs and wires were OEM and replaced approximately 3 months ago. The "sputtering" began yesterday while my wife was driving it. Wait.... maybe that was the problem. [&:]
Old 11-01-2007, 06:14 AM
Garon's Avatar
I should be able to work on the issue tomorrow morning, but until then, I have just been very careful and driving very little.
Another piece of info that may help with the diagnosis... I noticed that the idle "sputter" only occurs when the engine is hot. There is no rough idle the first few minutes in the morning when the engine is very cold.
Does this help narrow down the possible cause of problem?
Old 11-01-2007, 07:03 AM
riceburner700's Avatar
clean your IACV out its on the firewall side of the intake manifold, and it will more than likely take care of your idle
gmoney40
02-16-2011 04:56 PM
burgernuds
11-06-2008 06:07 AM
codered3x
10-25-2008 06:57 AM
ket_ket
09-12-2008 07:22 PM
britishav8tor
02-13-2005 02:50 PM
Quick Reply: Engine "sputters" at idle but not during acceleration
