Engine won't start when check engine light is on
Old 07-19-2005, 01:38 AM
Benny Sim's Avatar
Default Engine won't start when check engine light is on
Hi All,
I'm new here.
I have a problem with my D16Z6.
This problem came without warning.
Normally, when on the ignition, the check engine will stay for 2 seconds then the light went off.
But for my case, I have to wait for 10-15 minutes, then the check engine will go off. If i try to start the engine when the check engine is still on, the car will not start, like no fuel is supply to the engine.
I had changed the main fuel relay pump and the spark plug, but it still won't work.
Any advise??
Thanks.
Old 07-19-2005, 02:10 AM
Default RE: Engine won't start when check engine light is on
[sm=welcomesign.gif] to HCF. [sm=groupwave.gif][sm=groupwave.gif][sm=groupwave.gif]
Hopefully someone can help you out that had the same problem.
Old 07-19-2005, 02:20 AM
Benny Sim's Avatar
Hi,
You having the same problem as me??
Old 07-19-2005, 09:33 AM
AgentofDarkness's Avatar
Hook up a scanner to your car and check the code the scanner is giving you.
Old 07-19-2005, 07:43 PM
Benny Sim's Avatar
HI all,
Thanks for your advise. Problem sloved. The ECU is the main problem.
After changing to another ecu, it works fine just as the check light off within 2 seconds.
THanks Bro
chmiller25
07-23-2012 11:50 AM
zetojericho
08-01-2011 06:09 AM
towelie
08-30-2010 05:08 PM
vincevs
07-08-2009 06:25 AM
pace78921
12-11-2005 07:33 PM
Quick Reply: Engine won't start when check engine light is on
