New here and need help!
Old 01-30-2013, 11:17 AM
111ace's Avatar
Default New here and need help!
Hello everyone, i have a 98 Honda Civic I believe its a LX and its an automatic 4 door. I have a CEL Code for P1259, i searched around and saw that it was a v-tech code but my engine is not v-tech, its a d16y7. i have a taken a few pictures to show everyone and hopefully a way to fix it because it cannot pass inspection =/
Old 01-30-2013, 11:42 AM
Looks like you have a y8 (vtec) intake manifold.
I would suggest to confirm the trim level of your car. They did make EX sedans, too. You have confirmed the engine code is in fact D16y7? It should be stamped onto the block where the transmission is bolted to.
Find your ECU. If you are running an EX, or vtec ECU, I can imagine you will see a CEL for that since the solenoid is non-existent on your motor.
Old 01-30-2013, 11:43 AM
111ace's Avatar
yeah its stamped D16Y7 on the bottom left. What do i do now??
Old 01-30-2013, 03:32 PM
If you reset the code, I don't think it is thrown again unless you were to rev the engine to 5500 rpm. Only then the ECU will try to engage VTEC and it would discover there is no VTEC.
Old 01-30-2013, 03:49 PM
111ace's Avatar
Still thrown maybe there is a vtech ecu ? Perhaps changing it to a non vtech ecu will work
Old 01-30-2013, 06:51 PM
vtec.
Get the code checked.
Can you pull off the passenger side kick panel and tell us what numbers/letters are on the side?
Old 01-31-2013, 07:54 AM
111ace's Avatar
The epu is a p2p , a vtech epu I bought a p2e
Road_Clam
06-20-2011 08:38 AM
NismoSkylineGTR
10-21-2007 06:40 PM
CYmarlins
08-12-2007 12:38 PM
bLaZnGi2L
12-26-2004 07:13 PM
JIZZO
12-13-2004 08:25 PM
Quick Reply: New here and need help!
