Wanna change manual tranny oil in my 2000 civic. What oil to use?
Old 03-15-2008, 02:32 PM
STREETFIGHTER50's Avatar
Default Wanna change manual tranny oil in my 2000 civic. What oil to use?
I remember using 10w30 motor oil for my 1996 integra's 5 speed. What oil to use & is it the same procedures on the Civic's tranny?
Old 03-15-2008, 03:54 PM
Live_4it's Avatar
Default RE: Wanna change manual tranny oil in my 2000 civic. What oil to use?
I would use OEM Honda trans fluid thats what I used when I did it. I wouldn't use engine oil for the transmission. You just jack the car up take off the drain bolt with an extention bar and breaker bar. Use a hose line or any kind of tube that will fit inside the filler hole and will reach to the engine bay. I think it just needs a couple quarts, you'll tell when it's full once some fluid starts dripping out of the filler hole. It's also recommended to drop the car down and finish adding a little more fluid in.
Old 03-15-2008, 05:22 PM
are you asking to about the transmission fluid or the motor oil? trans. fluid i would go with oem from honda. if it is motor oil then it is 10-30
Old 03-15-2008, 05:25 PM
ORIGINAL: STREETFIGHTER50
Use only Honda manual transmission fluid as almost anything else can destroy certain seals in the transmission.
Old 03-15-2008, 05:30 PM
mill$civic's Avatar
CHeck out our DIY
https://www.hondacivicforum.com/m_293737/tm.htm
Old 03-16-2008, 12:15 AM
Thanks for the replies & the DIY! Also how often does everyone do the tranny service?
Old 03-16-2008, 08:08 AM
SevenKRedline's Avatar
Member
For a manual transmission, replacing the gear oil only needs to be done about every 120k miles or so. The stuff lasts forever!
oilltd
06-10-2008 04:06 PM
bs2000Hx
03-02-2008 12:52 PM
davster
09-28-2007 10:23 AM
BillyB98
09-18-2007 08:52 PM
Quick Reply: Wanna change manual tranny oil in my 2000 civic. What oil to use?
