93 Civic idles/starts poor when cold
Old 01-01-2015, 07:24 AM
doggpound's Avatar
Default 93 Civic idles/starts poor when cold
I have a 93 Civic CX hatchback that has recently started acting weird in cold weather. The other day it barely started, and wouldn't idle for the first 3x I started it. The starter sounded different and when it finally caught I had to give it some gas to get it to run. After that it idled fine. When the car is warm it starts right up but this morning I had to put a heater on it to get the starter to engage the engine. Has anyone else ever had this problem? Is there something heat-sensitive in the starter that would cause this to happen in cold weather.
Old 01-01-2015, 04:38 PM
bradykay90's Avatar
There's nothing in the starter thats heat sensitive... maybe oil to heavy for cold weather or bad oil pressure. I wouldn't say weak starter since its acting up when its cold but could possible be that. Have you check battery voltage with and with out a load
Old 11-29-2016, 07:52 PM
OEM-VX's Avatar
OK HERE IS THE SOLUTION.!!!
My vx was getting max highway about 48, average about 43 hwy, and city was about 33mpg.
I did all the other things everyone else did and still no improvement until I did the following:
Check the fuel pressure like the honda service manual says. My testing found it to be below spec.
I replaced the fuel filter and the pressure went up a little on one test but was still low on the other test(having to do with the vacuum line on the fuel regulator).
The test said that I should test the regulator, and if that was working it was the Fuel pump that was the problem. Which was what I did.
I replaced the Fuel Pump and the two pressure tests passed!
It ran amazingly different, but still had a tiny "miss" it seemed like, which was reduce quite a bit from what it was doing.
I decided to replace the Fuel Pressure Regulator just to make sure. (ebay $15)
The MPG went up dramatically with these fixes.
But, it was still feeling like the motor was off a little. So I checked the timing and it was off quite a few degrees! Must be the new pump and stuff affected the way it was firing and timing.
After setting the timing it ran perfect! No "missing", no hesitation, lots of power, smoother, quicker, 70 and even 80MPG on the highway on certain straight stretches.
I drove from Lake Charles LA to Tallahassee Florida and with the MPGUINO calibrated I got 61 MPG going 55-63MPH. That was a tank average after about 474 miles. The fillup said I got 59.7MPG
So Recap;
New O2 Sensor(NTK), new ntk plugs or E3 plugs, new cap/rotor, distributor, wires, cat convertor never got it above the 48-52mpg average for hwy.
BUT
A new fuel pump and screen, fuel filter, and fuel regulator, then re-setting the timing to proper 16 Deg BTDC(?) fixed all the problems of:
poor fuel economy, poor acceleration, poor power, poor smooth idling when it got hot, poor morning starts requiring me to try starting the car twice before it fired.
I can not tell you how freaking awesome this car runs now! It really amazing. It runs like it was brand new.
Oh, also add MotorKote to the engine oil to reduce friction. This product is amazing. It makes the surface tension of the metal tighter thereby reducing friction. Other additives dont do this, except a product called Militec(?).
Key words: How to get better MPG from honda civic VX?
My vx MPG sucks.
My civic vx wont start the first time, but will the second time i try to start.
My civic vx is missing at highway speeds.
My civic vx is not getting good mileage mpg need to increase.
My civic vx has poor acceleration weak power poor idle wont idle good.
I hope this helps people. It took me a few years and no one on the forums had solutions for any VX owners with these problems that solved it. This one works!!
Let me know if it helps you.
Jon Moore
15
05-27-2016 10:20 AM
Mecca8383
03-31-2014 05:15 AM
branx
07-02-2008 08:44 AM
97_ex
04-18-2007 09:29 PM
mikecivex
06-13-2006 04:02 AM
Quick Reply: 93 Civic idles/starts poor when cold
