Power windowns locks stopped working?
Old Oct 23, 2008 | 01:49 PM
Originally Posted by kev2809
it couldnt be a wire crossed somewhere? my windows and locks seemed to stop working when i was driving home from work and a wire behind my radio started smoking. when i pulled out the radio one of the wires was uncovered, so i covered it back up with the tape. so im guessing it touched something somewhere, but how could that wire pop a fuse and then make it act like a wire is crossed somewhere...
It's possible. What color/stripe did the damaged wire have? Since covering the damaged wire, are you now able to insert fuse 36 without it blowing?
Another possibility is that the shorted wire near the radio fried your under-hood fuse box. Consider removing the fuse box and inspecting it for damage.
Old Sep 28, 2009 | 09:06 AM
Arcangelwarrior's Avatar
Question Help!!!!!!!
I have a 2000 civic four doors and suddenly the doors locks stop working, when I use the remote control it only opens the two rear doors and the trunk, but the two front doors don't. I tried to buy an alarm thinking that may fix it but the guy told me I have to fixed the door problem first. The guy told me it may be only a blown fuse but I check every single fuse in the under the hood box and the inside box but everything is working. I took my car to the mechanic shop and they told me that the problem is a little motor in both doors that make them lock, so is this true or the guy in the mechanic shop is trying to make some money with me? anyway my car is getting fix but I just want to know that.
Old Sep 28, 2009 | 10:49 AM
well pull off your door panels and you will see the door lock poppers get a test light and hit the button and see if they are getting juice,
Old Oct 18, 2009 | 11:21 AM
blulite`'s Avatar
hey guys similar problem on my 96 civic, the windows work fine, but the door locks however dont work, any suggestions????????????????
Tigal
Mar 8, 2012 01:56 PM
eisenberg
Feb 14, 2010 07:14 PM
rcoursey
Aug 29, 2007 02:33 PM
Kturner
Sep 25, 2006 08:38 AM
poke4802
Apr 23, 2006 01:31 AM
