D16y7 Modding?
Old Aug 11, 2009 | 09:13 AM
Originally Posted by KingDakota12
Ok so im interested in doing the y8 swap and was just wondering what all ill need.
The y8 head and what else....
y8 head
y8 dizzy
y8 intake manifold(optional) but a gain to do it
head gasket
intake gasket
y8 wire harness to cut the plugs needed to re wire yours
knock sensor
obd2b vtec ecu (or jumper harness and convert to obd1 and get a p28 ecu and no knock sensor will be needed)
some extra wire
some ecu pins from a donor car
and since you have all that stuff off during swap go ahead and get new timing belt/water pump
Old Aug 15, 2009 | 09:12 AM
firecatf7333's Avatar
I have a 98 dx stock and i also am looking to add some speed. I plan on getting a turbo and running low boost, but would like to beef up the engine still making it a daily driver. How much HP does the mini swap get you? What other options are their to add HP besides the intake, exhaust ****.
Old Aug 15, 2009 | 09:32 AM
rc2904's Avatar
About 20-25 hp with minime swap I believe. If your going to be needing much more than that get a b16 or b18 swap. b18 is excellent if you plan on getting a turbo.
Old Aug 15, 2009 | 10:42 AM
Default re
I'm not buying an expensive turbo, and don't want to spend a couple grand on a motor swap. The mini me swap, with a decent turbo running bout 6-8 psi, exhaust, headers, and few other minor mods, where do you think that put me with a stock dx 1.6? 200-230 HP? If i do that and its still fairly reliable for a daily driver i'd be happy. Any other engine mods besides a complete swap and the mini me swap, staying reliable?
Old Aug 15, 2009 | 11:10 AM
Turbo manifold will replace your header.....
Old Aug 15, 2009 | 06:40 PM
Is this what is needed for the mini me swap if i have the 98 dx.
http://cgi.ebay.com/ebaymotors/96-00...=p4506.c0.m245
Old Aug 15, 2009 | 07:04 PM
You also need:
y8 dizzy
head gasket
intake gasket
knock sensor
some extra wire
But yes, that head.
Old Aug 15, 2009 | 07:07 PM
^^lmao pwnage
Old Aug 20, 2009 | 05:32 PM
http://rochester.craigslist.org/pts/1331227612.html
is this worth 150 and what else would i need for the mini me swap
Old Aug 20, 2009 | 06:57 PM
no thats not a good deal and its been said ^twice what all is needed.
