looking to do a b16a swap in my 91 hatch. advice?
Old Nov 4, 2009 | 06:25 PM
doctorz's Avatar
I found a D16Z6 locally. It has a reworked head with less than 20 miles on it. One problem it has a spun crank bearing. Dude wants $120 for it. Does that sound worth it?
Old Nov 5, 2009 | 06:02 PM
PunisherInOKC's Avatar
What makes you want to buy and repair a d16z6? IMO, not worth it. Only has 127Hp, vtec hits at 5500rpm with a 6900RPM redline.
Also, there are the unknowns about the motor. The head itself may be reworked with less than 20 miles on it, but question is how is the rest of the motor? You know of the spun crank bearing, but there could be other problems. The problems can easily become quite costly.
Old Nov 7, 2009 | 03:16 PM
doctorz's Avatar
OK I picked through the local salvage yards today. I found a 94 intergra with a b18b1, 5 speed tranny, wiring harness, ecu, rear disk brakes, and what ever I need for $700. Now the only question is what else do I need off the car for the swap? I have no idea how to do this swap. I know I need a mounting kit but do I need the fuel lines, or clutch petels for the hydraulic clutch? I'm lost and I'm going Saturday to get the stuff so I need to know what to get. What do you guys think? Good price? is it worth the swap? Help plz.
Old Nov 9, 2009 | 07:08 PM
doctorz's Avatar
Anybody?
Old Nov 9, 2009 | 07:15 PM
you need a manual cable tranny, the hydro trans wont work unless you spend 300$ just for the conversion plate, so sell it or trade it for a b series cable trans,
you will need to use your old engine harness and convert your car from dpfi to mfi,
and you will need to sell or not buy that ecu, you will need a obd0 to obd1 conversion harness and a obd1 ecu or buy a obd0 pr-4 ecu from an older integra
you will need the teg front suspension to hold the extra weight.
Old Nov 10, 2009 | 02:18 PM
doctorz's Avatar
Cool, I can get just the engine for only $300. So I can leave the transmission ecu and save some money. If I do that will I need the wiring harness to cut to make mine work? Man I'm worrying the hell out of you guys. Thanks for the help.
Old Nov 10, 2009 | 06:24 PM
my best suggestion is to save your money and look for a 90-93 integra and get the motor from it, this will save you alot of work and time and money, they come with a cable trans and everything.
Old Nov 14, 2009 | 04:47 PM
doctorz's Avatar
I'm going to get the 94 engine anyways because its a good price. Im going to get this. http://www.vexmotorsports.com/Innova...n-_p_1716.html. Look ok to you guys?
slowcivicdx
ED-EF Swaps
Aug 13, 2010 07:27 PM
95h22civic
Apr 24, 2008 01:40 PM
zimpel
Sep 12, 2007 09:27 AM
cadman421
EK Swaps
May 11, 2007 12:47 AM
jamo58
EG Swaps
Aug 28, 2006 05:47 AM
