d16y7 turbo
Old Apr 11, 2010 | 09:06 PM
  #21
crfnguyen's Avatar
i was gonna do the tapped oil pan.. and what size injectors should i use and where can i get them for a good price??
Old Apr 11, 2010 | 09:07 PM
  #22
Scott53092's Avatar
When I boost I am using DSM blue top injectors, they are 450cc and are usually about $100 for the set including the resistor box.
Where'd you get the turbo setup you got from? Local?
Old Apr 11, 2010 | 09:11 PM
  #23
crfnguyen's Avatar
yea i got it off craigslist from some guy in sac. ok so dsm blue top injectors 450cc.. and i want to get the obd1 ecu and the obd2 to obd1 conversion harness.. also if i want to run more boost do i just change out the spring in the waste gate??? im new to the turbo so im lost..
Old Apr 11, 2010 | 09:19 PM
  #24
Scott53092's Avatar
The wastegate spring is what keeps the boost from going past whatever psi the spring is at. You can swap out springs or get a boost controller. This website is SUPER helpful, take some time out to read it. http://www.beesandgoats.com/boostfaq/g2icturbo.html
What'd you pay for the setup? Came with some nice stuff.
Old Apr 11, 2010 | 09:52 PM
  #25
crfnguyen's Avatar
thank you ill be reading that for the rest of the night lol... i paid 800
Old Apr 11, 2010 | 10:20 PM
  #26
crfnguyen's Avatar
oh btw he also gave me a missing link...(have no idea what it is) he said you put it on your map sensor and it overides something....
also wat does a vacuum manifold do?
Old Apr 14, 2010 | 12:53 PM
  #27
A vacuum manifold provides a vacuum source for all your turbo parts. You have a vacuum source and you connect engine components that need vacuum to it.
Old Apr 14, 2010 | 07:28 PM
  #28
Scott53092's Avatar
The missing link I'm assuming will make the MAP sensor not read the postive vacuum pressure when under boost. Once a map sensor recognizes positive boost it will throw a cel and will actually shut off the car and put the ecu in "limp" mode, where you will need to reset it.
Old Apr 14, 2010 | 08:54 PM
  #29
theblackpearl's Avatar
you won't need the missing link if you don't go over 10 psi iirc
Old Apr 16, 2010 | 04:46 AM
  #30
crfnguyen's Avatar
ok so i dont need the missing link then im only gonna run 7-8psi but i need the vacuum manifold....
btw for anyone that lives in sac or near sac theres an import shop in south sac(florin rd. and 65 st.) called top speed....
i saw a 98 skyline gtr in the parking lot today....... almost wrecked my car trying to look at it...
