Old Nov 16, 2009 | 07:18 PM
  #501
danomatic93's Avatar
June 2010 ROTM
not much, if you want to meet up I'll make sure I'll be free.
Old Nov 18, 2009 | 09:05 PM
  #502
June 2010 ROTM
The engine is running great now. The input shaft bearing went on the trans so I swapped back in my Y8 trans. Well, all is great minus a rough start every once in a while. When starting it'll be boggy for 10-15 seconds and then it'll run like a champ from then on.
I neglected to post this must have swap picture...
Old Nov 19, 2009 | 10:35 AM
  #503
Lewy2k's Avatar
Good to hear! Mine runs a little different when it idles after a cold night. Havent thought too much about it since it runs great.
Old Dec 18, 2009 | 10:41 AM
  #504
June 2010 ROTM
This engine is pissing me off like no other!!
My thermostat failed a while ago. It thought it was a fail open but apparently it was a fail open or closed or whatever the hell it wants to do. I replaced it with a new fail open thermostat and while I was at it cleaned my Idle Air Control Valve.
After refilling all the fluids I go to start it and when I turn the key NOTHING! It sounded like the starter wasn't being activated. I thinking wtf?! I looked all around the engine bay for something that I might have unplugged for no reason. Couldn't find anything. I check all the fuses especially the "starter" fuse and they were fine. So I go the start it again and it started.
I was thinking I was nuts until this morning it wouldn't start for me. It sounds like the starter isn't being activated.
Old Dec 18, 2009 | 12:28 PM
  #505
kanarrjl's Avatar
that sucks time for a new starter?
Old Dec 18, 2009 | 12:45 PM
  #506
June 2010 ROTM
We'll see, I have to get off my butt and test things like the clutch interlock switch, starter, and crap.
Old Dec 18, 2009 | 12:53 PM
  #507
kanarrjl's Avatar
fun fun
Old Dec 18, 2009 | 08:35 PM
  #508
Sigracer10's Avatar
if you can't figure it out try making sure the starter wire at the ignition switch is getting +12V. the might be starting to get worn out, and if the starter wire isn't get current, then nothings going to happen further down the line.
Old Dec 18, 2009 | 10:02 PM
  #509
June 2010 ROTM
I tested the clutch interlock switch and it tested out okay. I then went to check the wires that were directly connected to the starter and found this...
Seems that the small wire to the starter had a broken wire connector! Since my 50 pack of female wire connectors is at my parent's place I had to pick up some at the hardware store. First thing tomorrow I'll be getting that done. Hopefully this will do the trick.
Old Dec 19, 2009 | 04:31 AM
  #510
ya that ill do it. at least ya found the spot....
