Trunk Release Lever
Old Sep 10, 2005 | 08:18 PM
vdog's Avatar
Default Trunk Release Lever
I tried to open my trunk by way of the lever inside the car, nothing happens. I turned the key each way not knowing which is lock or unlock, again it will not open.
The lever does not have slack and still fells taunt, like its releasing.
What do I need to do?
Old Sep 10, 2005 | 08:34 PM
absoulute's Avatar
Default RE: Trunk Release Lever
check the lock. open it with your key there is a lever under there that u can disable the inside lever
Old Sep 10, 2005 | 09:53 PM
vdog's Avatar
So I need to pull the plastic cover up, correct?
Old Sep 11, 2005 | 01:26 AM
NTX's Avatar
NTX
i had a similar problem. turned out the cable was not attached in the trunk.
Old Sep 11, 2005 | 09:26 AM
absoulute's Avatar
or wait nevermind on my post my civic has a switch that u can hit and it disables the key on the trunk yea check to make sure the cable is attached
Old Sep 11, 2005 | 05:37 PM
amg6975's Avatar
Make sure that the key clicks, It will move back and forth freely but it has to click and stay in the position to unlock it.
Old Sep 13, 2005 | 05:49 PM
vdog's Avatar
My key does turn either way, but there is no click. Help!
burnindesirez02
Jan 29, 2010 01:53 PM
misterxandy
Dec 22, 2009 12:19 PM
burnindesirez02
Apr 10, 2008 02:17 PM
00IntegraLS
Mar 13, 2008 10:41 AM
Littleneckhalfshell
Feb 24, 2005 03:24 PM
