zc swap into a 88 4 door dx
Old Dec 19, 2005 | 02:20 PM
yorky's Avatar
Default zc swap into a 88 4 door dx
hey, iwas wondering if anyone had any suggestions on a zc swap into my 4 door civic? like parts needed and wiring?
Old Dec 20, 2005 | 04:47 PM
finalimpact's Avatar
Default RE: zc swap into a 88 4 door dx
dohc or sohc zc? most likely your going after the dohc version so in that case. you must convert to mpfi as your dpfi manifold wont bolt up to the dohc zc head.
Old Dec 21, 2005 | 12:55 AM
Kappa22's Avatar
DOHC ZC, any 4G tranny, 88-89 Integra 5-spd ECU (PG7), injector resistor box from any MPFI Civic/Integra, old ECU plugs to pull pins from, surplus wire and looming.
Old Dec 22, 2005 | 03:59 PM
ef4life's Avatar
for a tranny you must use the flywheel and clutch that is for that transmission. a si trans, si clutch, si flywheel. some years and models came with different sizes, and won't be compatible.
hydro_yang
Sep 12, 2009 01:18 PM
nate2002
Jan 22, 2008 12:31 PM
mrsuburban
Feb 11, 2007 07:43 PM
windcalmer
Jun 9, 2006 01:52 PM
yorky
Dec 19, 2005 02:20 PM
