GRR!!
Old Dec 27, 2005 | 07:59 PM
XCM828's Avatar
Default GRR!!
Man this kit is really starting to **** me off. The fitment isn't exactly great. I've had to modify way too many things to get this kit together. What should I do about this:
[IMG]local://upfiles/1204/950C96D6474E46F1ACF94FE73D6F2F26.jpg[/IMG]
[IMG]local://upfiles/1204/65F7F578999C42C79CD2B12D8F0CDB84.jpg[/IMG]
Old Dec 27, 2005 | 08:00 PM
XCM828's Avatar
Default RE: GRR!!
more
[IMG]local://upfiles/1204/A66741CE58EA41CC9959AF010A9185A0.jpg[/IMG]
[IMG]local://upfiles/1204/F333DFF8F59C40C58BFD61A1463F46BE.jpg[/IMG]
Old Dec 27, 2005 | 09:23 PM
AgentofDarkness's Avatar
Default RE: GRR!!
Hit it with a hammer, even if it doesn't work you will feel better. I've never done this before, but maybe you should try heating with a torch and bend the hose to fit. But that looks like aluminium piping, so heating it might not work.
Old Dec 27, 2005 | 09:54 PM
Nail I3unny's Avatar
Default RE: GRR!!
[sm=funnypostabove.gif]
but i was thinkin along the same lines as the heating things. if not you could probably cutit a bit and use a thick rubber hose to connect it.
Old Dec 27, 2005 | 09:56 PM
Default RE: GRR!!
wait heres another thought. how hard would it be to get to the bottom pipe?
Old Dec 27, 2005 | 10:42 PM
XCM828's Avatar
Default RE: GRR!!
Bottom pipe? I've tried hitting it a lot, but it just won't fit. And I don't have a torch. I might just take it in to the muffler shop with the pics and see if they can bend the sucker.
Old Dec 27, 2005 | 10:56 PM
Micter's Avatar
Default RE: GRR!!
Don't heat it with a torch as Aluminum is somewhat flamable.
I would loosen both sides up 'til the ends fit together then tighten each side slowly so they bend into place. It might be a stretch but very worthy of a try.
Old Dec 27, 2005 | 11:06 PM
Default RE: GRR!!
well what im thinking is you could cut them a little shorter...like no more than a cm or two each...then cut them and rotate them till they fit. just a thought.
Old Dec 27, 2005 | 11:15 PM
Default RE: GRR!!
I think that an oxy/acetalyn torch is gonna be way too hot for aluminium, as that will turn iron red hot. I have a propane torch, i'm pretty sure its flame is a little cooler. So maybe the propane torch won't burn the aluminium, but will heat it enough to bend. You can find the propane torches at Home Depot (or a similar store) in the plumbing department for like $40. But the muffler shop isn't a bad idea, they should know how to bend piping.
Old Dec 27, 2005 | 11:29 PM
riceburner700's Avatar
Default RE: GRR!!
just vent it to the atomesphere until you can get an exhaust shop to make you a custom one or make it fit....
problem solved
