advice from the experienced to the less experienced
Old Nov 1, 2004 | 07:33 PM
newbie's Avatar
Default advice from the experienced to the less experienced
This is my first time in the forums. I have a 2002 Civic EX....stock 127 HP. I have been told that the best way to increase my HP is through a cool air intake. Is this true? If so what is a good intake to get? I also live in Ohio where the temperature changes drastically from winter to summer...I was reading something about a Cold Air Intake that you change in cold temperatures...is that really necessary? Also...should I stick with the stock engine or should I try to save for a new engine? I also need some help in the way of exhaust systems. What should I get from the cat back and what should I get in the way of manifolds??? Should I keep my existing cat and just replace the manifolds and stuff from cat back???
Old Nov 1, 2004 | 08:54 PM
Default RE: advice from the experienced to the less experienced
you can get a dohc k-series motor for those civics. but it is VERY expensive, and it hasnt been done as much as a typical 88-00 dohc swap. for now i'd stick with the stock motor. maybe a turbo or supercharger would be better. as for the intake, you only need to change it around if you get a lot of rain and stand a chance of sucking water up from big puddles. i'd start with the intkae, then move on to the other ins and outs. i dont know about other brands, but the OBX header for your car also replaces the cat. though i wouldnt recommend it, it has a big lip that would hurt gas flow on the outlet.
Old Nov 1, 2004 | 09:16 PM
newbie's Avatar
Thanks a bunch Sacicons. Do you have any recommendations for turbos? I read the forums on S/C versus turbos and I think I would be better off with a turbo for my needs. After the air intake...what are usually the next few things to change excluding the exhaust system because i already know I need to do that Thanks again for helping out the newbie
Old Nov 1, 2004 | 09:25 PM
k, if your planning on going turbo, dont bother with the intake, it wont fit with the turbo on there. im not sure who makes a turbo kit for the 01 and up civics, but try greddy first, theyre usually the first ones with new applications.
Old Nov 1, 2004 | 09:42 PM
newbie's Avatar
Ok, I am assuming though that it's much better to go with a turbo than to go with an intake if I had to choose between the two, right?
Old Nov 1, 2004 | 10:46 PM
right.
mossberg
South
Oct 4, 2011 08:57 AM
iluvfreklz
Jan 21, 2009 04:40 AM
Stimpy
Apr 25, 2007 07:09 AM
billanderson
Jan 14, 2007 11:09 PM
Roost3r
May 22, 2005 05:43 PM
