ZC turbo kits?
Old Dec 4, 2004 | 03:58 PM
Kappa22's Avatar
Default ZC turbo kits?
Hey all you knowledgeable turbo types. I'm looking for a turbo kit for a Blacktop ZC motor, or any kit for a USDM equivalent that will work on a ZC. Know of any companies? Please don't hesitate to let me know.
Old Dec 4, 2004 | 08:03 PM
andryuha's Avatar
Default RE: ZC turbo kits?
The turbos aren't specifically made for each kind of motor. Technically you could use ANY turbo you want. However, you would need a manifold for that turbo that you could fit to your engine.
Old Dec 4, 2004 | 09:52 PM
dont the sohc exhaust manifolds bolt up to the zc motors? not sure, but i think i read that somewhere. if so, then it would be easy to get a mani for a sohc and make it work. even an old stock hf manifold will work with an adapter plate for a turbo to bolt to the bottom
Old Jan 25, 2005 | 01:01 PM
turboedciv's Avatar
You do not need to go out and buy some expensive kit, you can go down to your local wrecking yard and piece it all together. It does take some work but when your done you will be happy. A good site to learn what to do is www.homemadeturbo.com read all the forums there and get familiar with what you want to do with your car
Good Luck
FlipHKD720
Sep 28, 2006 08:47 PM
xramseyx
Apr 19, 2006 05:44 PM
javierdagreat
Dec 19, 2005 07:55 PM
Pacman133
Nov 18, 2004 12:21 PM
