Ceramic Vs. Stainless Steel
Old Dec 11, 2004 | 05:52 PM
D16z6's Avatar
Default Ceramic Vs. Stainless Steel
Exactly whats the difference between caermaic and stainless steel header???? I noticed that ceramic is much more cheaper than stainless steel. Which one would you recommend???
Old Dec 11, 2004 | 07:41 PM
no9t9's Avatar
Default RE: Ceramic Vs. Stainless Steel
why did you post this again?
https://www.hondacivicforum.com/m_11633/tm.htm
bottom line, ceramic is better performance and stainless looks better
Edit: sorry my mistake.. u were asking about chrome before. Stainless and chrome are pretty much the same. they don't perform the same as ceramic in heat isolation.
Old Dec 11, 2004 | 08:03 PM
yeah, ceraminc is usually better. but some of the high quality headers have stainless steel with a ceramic coating inside. in that case they are about the same, but the SS looks cool once it heats up and it turns a lot of colors.
Old Dec 12, 2004 | 07:22 AM
polo708's Avatar
even stainless steel/chrome intakes... look good for about a month, then they fade and turn to ****.
Old Dec 12, 2004 | 11:20 AM
oh yeah, powdercoated is the only way to go on intakes unless you want to be polishing it all the time.
Old Dec 20, 2004 | 07:58 PM
D16z6's Avatar
Thanks for the tip. I guss ill get a dc sport 4-2-1 ceramic header then but there is one more thing i need to know. Whats the difference between 1 and 2 piece header??? Which one would you recommend?
Old Dec 20, 2004 | 08:15 PM
fast93civic's Avatar
I my self don't see any difference, but you know what they say, less pars, less trouble.
Andrey
Old Dec 21, 2004 | 01:53 PM
green98lxsedan's Avatar
a 2 piece mightbe easier for you to install on your own. but if you have a buddy or 2 aroudn then the 1 piece will be easy too. will run less of a risk of an exhause leak with a 1 piece also
Old Dec 21, 2004 | 09:04 PM
yeah, 2 piece is way easier to install. but i like one piece better, less weight and less bolts. i hate those stupid exhaust bolts. and put antisieze compound on exhaust bolts.
zoom24
Feb 19, 2009 02:51 PM
1999siguy
Oct 26, 2007 12:37 PM
Talon585
Apr 21, 2006 05:46 PM
jad1217
Dec 17, 2005 04:24 PM
plc00133777
Nov 2, 2005 09:38 PM
