tranny
Old Dec 15, 2004 | 03:42 PM
ilinihonda's Avatar
Default tranny
I just got an engine and 5 speed tranny to replace the one in my 91 civic. The existing one is a 4 speed. Would it be possible to use the 5 speed tranny, and what all is involved in changing it. Is the clutch different?
Thanks in advance
Wendy
Old Dec 15, 2004 | 05:00 PM
Kappa22's Avatar
Default RE: tranny
Yes, you can use the 5 speed in place of the stock 4 speed. It doesn't require any kind of conversion or extra parts. Same clutch, same axles, same everything.
Old Dec 15, 2004 | 05:06 PM
SiRacer's Avatar
Default RE: tranny
Any tranny that fits on a honda civic will fit doesnt matter wat speed 4, 5, or 6
Old Dec 15, 2004 | 05:24 PM
ilinihonda's Avatar
Default RE: tranny
That will make things go alot easier. Thanks
Old Dec 15, 2004 | 07:32 PM
Default RE: tranny
hold on a sec. thats only true between series. a d will fit a d, a b will fit a b, a k will fit a k. and it will only work in a car with the same kind of clutch modulation. cable or hydrolic.
Old Dec 16, 2004 | 11:28 AM
Kappa22's Avatar
Default RE: tranny
Yeah. I was going to call him on that too. Any 4G D series tranny will work, NOT any Honda tranny. And 4G's didn't have hydraulic clutches, so you don't have to worry about that.
Old Dec 16, 2004 | 09:12 PM
ohbiskits's Avatar
Default RE: tranny
what all do i need to a 5 speed conversion/ or manual tranny conversion in general. i have a 4th gen...this is what i have gatherd is there anything else?
break and clutch pedal assembly
clutch cable
shift linkage
transmisson
full clutch/ p plate ect.
axels
is there anything else i need?
Old Dec 16, 2004 | 11:59 PM
Default RE: tranny
something easy to overlook, do you have a shifter? if not, look into one froman old prelude. 88 or somewhere thereabout. my friend used to have one in his crx. it was nice, it was shorter than most aftermarket shift throws and had a nice handle. i think it bolted right up with the boot and everything.
Old Dec 17, 2004 | 11:39 PM
ohbiskits's Avatar
Default RE: tranny
cool...u think thats better then like a sk2 short shifter or sumthing of the such?
Old Dec 18, 2004 | 12:57 AM
Default RE: tranny
i liked it.. try to look at one and see if you like it.
