Air/Fuel ratio gauge
Old Nov 14, 2006 | 02:05 PM
BGFastCivic's Avatar
Default Air/Fuel ratio gauge
I have 2004 civic 1.7 liter, does anyone know where my purple wire on my a/f ratio gauge hooks into? I know into the ecu wiring or the header but what color is the wire?
Old Nov 14, 2006 | 05:48 PM
TheMoogly's Avatar
Default RE: Air/Fuel ratio gauge
I cant answer your question but I am wondering what you are installing? Can you take pictures? Are you an EX?
Old Nov 15, 2006 | 08:04 AM
First, why do you need an AFR gauge, are you running F/I? Is it wideband controlled? If it's not running off a wideband, then it's a completely useless cluster of blinky lights.
Old Nov 15, 2006 | 08:13 AM
RIPPS A LOT's Avatar
hey whats up i have a fuel air ratio meter it hooks into the wire on the harness for the O2 sensor it installs on the wire with the voltage reading.5volts-1.5volts back to ground if you probe the wire while it is on that is the only way to tell sorry no wire color can help they are different for year make modle etc.
kirkspooky
Jan 17, 2008 11:16 AM
03civiclxcoupe
Mar 5, 2007 08:22 PM
96civic285whp
Jun 16, 2006 10:04 PM
lilpooh21186
Mar 15, 2006 07:52 PM
red_sleeper
Jan 26, 2005 06:51 PM
