t HELP WITH ALARM INSTALL
Old Dec 4, 2006 | 07:02 PM
D16DAVE's Avatar
Default t HELP WITH ALARM INSTALL
I just bought an alarm and plan on installing it myself. can anybody give me a diagram on a 98EX where the best place to splice in to the factory wires would be. and if you could give me the colors of the wires also. i have the wiring diagram that came with the alarm but i want a clean easy install. not wires ran all over the place you know keep in in th same area.if it helps it is a fusion f-2000
Old Dec 4, 2006 | 09:00 PM
D16DAVE's Avatar
Default RE: HELP WITH ALARM INSTALL
nobody ??????????????????
Old Dec 4, 2006 | 09:21 PM
kman92civicsi's Avatar
call up audiovaux, SPELLING, umm i know you can get the wiring diagrams from them they will fax it to you
Old Dec 5, 2006 | 02:48 AM
dukat03's Avatar
HERE YOU GO THIS IS FROM DEI THE COMPANY WHO MAKES VIPER , CLIFFORD ALARMS
[IMG]local://upfiles/16447/7EF05A72BAB54788A477EE5E10F163CD.gif[/IMG]
[IMG]local://upfiles/16447/D318A093BAF342E09F5211ABAAC36CF1.gif[/IMG]
Old Dec 5, 2006 | 11:30 AM
Method's Avatar
my advice is that, if you don't know what your doing ie: electrical baclground, you should get someone else to do it.
Old Dec 5, 2006 | 12:38 PM
KarTuneMan's Avatar
MODEL YEAR(S)
CIVIC 1996 -1998
KEY T-HARNESS IMMOBILIZER
N/A HON-1 N/A
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) IGNITION SWITCH HARNESS
STARTER BLACK/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 YELLOW (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 WHITE/BLACK (+) IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) RED/BLACK (+) IN DRIVERS KICK PANEL
POWER LOCK GREEN/WHITE (TYPE B) @ BLUE PLUG IN DRIVERS KICK PANEL
POWER UNLOCK GREEN/ORANGE (TYPE B) @ BLUE PLUG IN DRIVERS KICK PANEL
DOOR TRIGGER LIGHT GREEN/RED (-) LOW IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION LIGHT GREEN/BLACK (-), Requires Part #775 Relay IN DRIVERS A PILLAR
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN BLUE to GRAY @ STEERING COLUMN HARNESS
TACH BLUE, See NOTE *1 @ TACH TEST CONNECTOR
WAIT TO START LIGHT N/A
BRAKE GREEN/WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFT N/A
EXTRA INFORMATION
NOTE *1 THE TACH TEST CONNECTOR IS LOCATED UNDER THE HOOD ON DRIVERS SIDE FIREWALL.
Dive in man....it's a simple car.
Old Dec 5, 2006 | 07:02 PM
instaling the alarm is preaty easy....
just remember jif you do it yourself do it right.........
you need to make good conections... and tape over all your wires so it looks close to factory at least and not a huge mess under the dash where someone can just look under the dash and just pull the one siren wire or just pull all the wires out.... also zip tie the alarms brain and relays pu high in the dash! make it so you cannt just reach up thier and pull down the brain...
ALSO check every entry location and make sure your alarm is properly triggered when opened...
i still havent wired in my trunk sensor yet.LOL but my stereo setup prevents them from realy stealing anything.LOL
AND MOST IMPORTANT............ PROPERLY ADJUST THE SHOCK SENSOR!!!!!!!!!! i hate it when people just crank up the sensro to full and have all the annoying false triggers pissing EVERYONE OFF!!!!!!!! LOL
Old Dec 7, 2006 | 07:48 PM
D16DAVE's Avatar
thanks guys espeically dukat it really helped
Old Dec 9, 2006 | 07:03 PM
dukat03's Avatar
Glad i could help if you need anything else let me know , that goes for anyone else that needs help
Old Dec 12, 2006 | 05:36 PM
sry bout the post in the other forum, u seem like u have connectrions for accurate info
zerojett
Jan 18, 2012 02:07 PM
90497hx
Aug 12, 2010 04:42 AM
BruceK
Aug 4, 2007 09:15 AM
93civicguy
Feb 20, 2007 06:09 PM
Mikedg186
Aug 4, 2005 11:18 PM
