autopage alarm install help? unlock prob.
Old Aug 10, 2010 | 04:31 PM
90497hx's Avatar
Default autopage alarm install help? unlock prob.
Alright I hooked up my alarm today and everything works except when I disarm it the drivers door does not unlock. The switch on the door unlocks and locks both doors, but when I disarm the alarm it only unlocks the pass. side door. I just bought the car a couple months ago and I don't think it's the original drivers door, but like I said the door switch works for both. I am just baffled and any input would help.
Old Aug 10, 2010 | 04:42 PM
90497hx's Avatar
I just saw a post about having to run a jumper on the stock radio wiring connector for the dome light to work properly w/ a aftermarket radio installed. I noticed that the door lock wiring goes through it also. Still not sure if that will help me but just throwing it out there.
Old Aug 10, 2010 | 04:57 PM
Sigracer10's Avatar
no ones gonna be able to help without knowing you vehicle's year and submodel, as well as what kind of alarm. give us that info and we might be able to help out.
Old Aug 10, 2010 | 06:38 PM
90497hx's Avatar
Sorry about that it's been a long day, car's a 97 hx, i don't think it had factory keyless in it. Alarm is a autopage rf-320.
Old Aug 10, 2010 | 08:15 PM
Sigracer10's Avatar
first off, where did you pull the unlock wire from?
according to this: http://www.the12volt.com/installbay/...tail/1050.html
you should have pulled it from behind the factory radio.
if you pulled it from somewhere else, it may be causing your problem.
Old Aug 11, 2010 | 05:03 AM
90497hx's Avatar
i pulled it from the blue plug in the drivers kick panel
Old Aug 11, 2010 | 10:45 AM
Sigracer10's Avatar
try pulling it from the green plug behind the radio, Green/Orange (-) wire, and see if that works.
most likely the wire that you tapped into is after the switch on the driver door on its way to the passenger door. So it will read as an unlock wire, but when the alarm sends the (-) signal on the unlock wire, it only unlocks the passenger door because the driver unlock motor is on the other side of the lock switch so it never sees the signal.
hope that makes sense
Old Aug 12, 2010 | 04:42 AM
90497hx's Avatar
I will give it a try next week on my day off(Tues.) and let you know. Thanks for the help hopefully that will do it.
aokec
Feb 26, 2010 05:08 AM
Tinkerbell_too
Jan 17, 2009 10:56 AM
BruceK
Aug 4, 2007 09:15 AM
Faithbleed
Oct 22, 2006 05:51 PM
01CivicEX
Apr 20, 2005 09:37 PM
