c'mon guys,,need help
Old Aug 12, 2010 | 12:06 PM
tng6664's Avatar
Default c'mon guys,,need help
'99 honda civic 1.6 ltr 4cyl. it has new water pump,,no thermostat,when full of water i can drive for about 25/30 mins.temp sets about half way,,all at once temp. will jump up in the red,,mostly all water is out of radiator when i shut it down,,,timing is set perf..no water in oil,,no smoke,,not skipping/missing..was thinking maybe head gasket,,but no signs i'm familiar with,,and when running can't detect no leak
Old Aug 12, 2010 | 12:15 PM
Top off the cooling system with fluid and let the engine idle with the hood open for an extended period of time. Watch carefully for leaks. Turn the engine off if when it begins to overheat.
Reinstall a good thermostat. Running without it is bad for the engine.
Old Aug 12, 2010 | 12:55 PM
tng6664's Avatar
Default overheating
i understand running without thermostat is not good,,but putting a new thrmst back in is not going to stop it from overheating,,as it did with and without thrmst
Forty04
Mar 9, 2007 09:12 PM
txedomask433
Aug 29, 2006 07:15 AM
chaseman1978
Oct 3, 2005 03:57 PM
Remmy
Mar 16, 2005 09:12 PM
gringo62
May 30, 2004 08:20 AM
