Alarm install in a 2000 SI
RE: Alarm install in a 2000 SI
Your wiring info for the car will prob be at www.the12volt.com They are kind enough to list wire locations and function for almost any car. Check it out.
Here is the wiring for your car for your alarm install.
2000 Honda Civic Security Information
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness or White 6 Pin Plug behind Fuse Panel
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Yellow Ignition Switch Harness
Accessory Yellow (+) Ignition Switch Harness
Tach Blue Coil
Neutral Safety Wire Black/Blue (-)
Brake Switch Green/White Brake Switch
Trunk Pin Blue/Black (-) Driver's Kick or Alarm Connector right of Column
Parking Lights Red/Black (+) Keyless Entry Module or above Fuse Panel
Head Lamp Red/White left. Red/Blue right at Steering Column
Door Trigger Light Green/Red (-) Alarm Connector right of Steering Connector is Green
Door Lock Green/White (-) Above Fuse Panel or Keyless Module or behind Radio Green Connector
Door Unlock Green/Orange (-)
Driver's Lock White/Red Driver's Kick Panel
Driver's Unlock Blue/Red Driver's Kick Panel
Passenger Unlock Yellow/Red Keyless Entry Module
Horn Wire Gray (-) Steering Column or Green Connector behind Radio
Windows Up LF=Red/Blue, RF=Blue/Yellow, LR=Green/Yellow, RR=Yellow
Windows Down LF=Red/Yellow, RF=Blue/Orange, LR=Green, RR=Yellow/Green
Tach Blue Coil
BruceK
08-04-2007 09:15 AM
