Turbo on a d16y8. Worth it?
Old Dec 5, 2006 | 11:43 PM
WhiteRabbit1021's Avatar
Default Turbo on a d16y8. Worth it?
Well, As most of you know I'm looking to turbo my car.
Only concern is, as I learn more it's getting more and more expensive.
As far as I understand if I turbo'd my car right now I'd only be able to run about 4psi because my fuel pump and pressure regulator can't handle it. I also may need bigger fuel injectors. This is turning out to be pretty expensive and if I didn't get all those new/bigger things I'd be only gaining about 30hp. So why do that when I can do a bunch of little things that are less expensive for the same gain?
Am I right about the fuel pump and what not or am I just being psycho?
I want the most for my money, that's pretty much what's going on here.
Old Dec 6, 2006 | 12:04 AM
Pete's Avatar
Default RE: Turbo on a d16y8. Worth it?
Its totally worth it. Say you buy a custom turbo kit for 1,000 DSM injectors for 75 and a resistor box for 25. Thats 1100. Get a good tune and your engine can handle 200whp. That would be like 85more WHP. A good tune might cost you 500 bucks, but it is worth it because it makes your engine run 110% properly.
Old Dec 6, 2006 | 07:45 AM
Boosting a y8 is soooo ****ing worth it, but it's by no means a cheap/easy task. I would try and give yourself 2 grand to play with. You most likely will not use all of that (especially if you consult us experienced guys before buying parts to make sure you're getting a good deal). But, having that extra "Cash cusion" is crucial because you WILL run into unexpected expenses...nature of the beast.
Also, find someone who is familiar with tuning the y8, because the timing can get quite tricky. Best solution is to swap the head with a z6, but, that's more money right there. Pay to play
Old Dec 6, 2006 | 09:57 AM
Remmy's Avatar
Its getting mroe expensive eh? If it makes you feel better, Ive dropped literally over 5k into my rebuild right now.
Old Dec 13, 2006 | 09:21 PM
94SOHCTURBO's Avatar
i love d series and a turbo just makes it so much better. mine is fully tuned with a custon saab turbo setup. got it dynoed and its pushin 220 at 8 psi. if you do it right its well worth it
Old Dec 27, 2006 | 10:09 PM
mugen23's Avatar
turboing my sohc going to run like 7-8 psi should i get bigger injectors or can i go around it and just get fuel pump and fuel regulator
Old Dec 27, 2006 | 11:10 PM
Street Sniper's Avatar
A stock fuel pump can handle moderate boost, but most are tired and need replacing anyway, soit's a good ideajust to upgrade. They are only ~100 bucks. The stock fpr is fine for meow.
What's your budget? I doubt you wanna go ghetto like I did, but it can be done.
pj400507
Sep 20, 2010 05:02 PM
silver2000civic
Jul 21, 2010 09:06 PM
nautik
EK Swaps
Mar 8, 2007 07:22 PM
slowcivicdriver
Jun 24, 2006 11:06 PM
Tenner
Nov 11, 2005 12:03 AM
