aftermarket cam
Old Dec 8, 2006 | 12:45 PM
4doorturbo's Avatar
Default aftermarket cam
what should i do for a cam setup for a b20 head? is there any out there or am i looking at a regrind.
Old Dec 8, 2006 | 07:43 PM
MY99SI's Avatar
Default RE: aftermarket cam
use a b16 head they flow the same as the ITR b/c they were both made on the same casting line from the factory but the ITR has more refinements done toit
do a stage 1 cam on stock valvesprings ifyou want to keep it below 9K rpm valve springs and retainers if you want to go above that
Old Dec 8, 2006 | 08:25 PM
a b16 head isnt a b20 head.....
just use factory LS cams. they are a slight upgrade from the stock B20 cams, and are pretty cheap.
Old Dec 9, 2006 | 02:24 PM
MY99SI's Avatar
why would you want to use the b20 head tho?
Old Dec 9, 2006 | 03:08 PM
Marty's Avatar
crower has cams for the LS and CRV head
Old Dec 9, 2006 | 06:18 PM
MY99SI's Avatar
still havenet answered my question lol y would you sacrifice the upper rpm hp with vtec and better flowing head of the b16
Old Dec 9, 2006 | 06:30 PM
Marty's Avatar
because the b18 and b20 bottom end needs to be gone through before you put a B16 head on it.
99silverSI
Aug 25, 2007 09:43 PM
dustin_crxsi
Jan 26, 2007 12:59 PM
civicblend97
Apr 29, 2006 01:12 AM
Pete
Oct 13, 2005 11:32 PM
Dickie
Jan 16, 2005 05:56 PM
