1992 Honda Civic Auto-Manual Conversion
Old Mar 10, 2005 | 05:56 PM
boarder102586's Avatar
Default 1992 Honda Civic Auto-Manual Conversion
I have a 1992 Honda Civic Ex Automatic and i also have a parts 1992 honda civic lx manual. I want to swap the auto for the 5 spd but i'm not sure how to go about it. I'm also looking for a new clutch. Does anyone know if i have to change the cv axle's. I need a lot of help
thanx
tim
Old Mar 10, 2005 | 08:06 PM
finalimpact's Avatar
Default RE: 1992 Honda Civic Auto-Manual Conversion
post needs to be posted in the transmission section. but to answer your question,
parts list
92-00 5spd tranny
92-00 shift linkages (d-series exc. del sol)
92-00 pedal assembly(or choose to use only the clutch pedal and cut down the brake pedal)
clutch master with resevoir
hyd. master lines(lines from clutch master cyl to slave cyl.)
slave cyl
92-00 front transmission mount and bracket(auto will not work)
92-95 5spd ecu
your factory automatic axles WILL work with the 5spd conversion. ive done this many times and IMO well worth the effort.
Old Mar 15, 2005 | 11:58 AM
Amanda's Avatar
I moved it to the correct section...
~Amanda
whitenic
Mar 10, 2010 05:14 AM
gvox
May 18, 2006 05:39 PM
1994TurboCivicEx
May 17, 2006 06:56 PM
z6 FoRiLLa
EG Swaps
16
Oct 21, 2005 09:19 PM
boarder102586
Mar 10, 2005 08:06 PM
