turbo ?s
Old Jun 9, 2004 | 11:11 AM
green98lxsedan's Avatar
Default turbo ?s
turbos are a little foreign to me. how does one go about increasing boost in a turbo?
and is it tough to get a turbo'd engine tuned correctly?
Old Jun 9, 2004 | 01:29 PM
NTX's Avatar
NTX
Default RE: turbo ?s
A good boost controller should allow you to increase or decrease the boost you want to run.
An engine that isn't designed for a turbo could be tricky to tune. I'd recomend purchasing a good engine management system.
Old Jun 9, 2004 | 01:45 PM
how does a boost controller work? is it electronic or mechanical?
Old Jun 9, 2004 | 01:50 PM
polo708's Avatar
turbos are adjusted by a boost controllers and Superchargers are adjusted by changing the pulleys...
Boost controllers that I have seen are adjusted electronically... I had one in the old civic but didnt really know alot about it. It was pretty much set and I rarely touched it.
Old Jun 9, 2004 | 02:59 PM
yea thats what i was tryin to figure out. i knew the pulley was changed for superchargers. i didnt know what wold be adjusted in a turbo since theres no pullies.
just thinkin bout a turbo for the civ. not that ide change the boost anyway in this car but got curious
Old Jun 9, 2004 | 04:26 PM
lilol89crx's Avatar
boost adjustments on a turbo can be done 2 ways, modifying the wastegate arm(internally wastgated) or with an adjustable boost controler either electronic or manual type. and if your going to turbo ur civic i do recomend an safc/vafc and larger injectors at least for fuel managment as compared to the fmu. if you can afford it, try to get a stand alone type unit. you may however be able to find a shop with a dyno that will be able to burn you a chip for your ecu to best suit your turbo set up. ive done a few installs where we used only an fmu, it ran alright but a little leaner than i wanted it and also fuel pressure was a little jumpy.
soldout712
12
Oct 30, 2006 11:05 PM
eg9
May 22, 2006 04:43 PM
forrealb50
Mar 29, 2006 07:57 AM
TrailorParkPimp
Aug 28, 2004 12:21 PM
