MT Fluid: to change or not to change
Old Jul 26, 2007 | 08:06 PM
iwishiwasemo89's Avatar
Default MT Fluid: to change or not to change
Hi, I just recently bought a '98 DX man transmission.
I've been sorta tuning it up cuz i have no idea how the other owner treated it. so im pulling out all the stops (oil, all filters, spark plugs, etc) and I was planning on changing my own trans fluid. BUT i couldnt get the fill bolt off. (a sign from God not to try to change it myself maybe?) But yeah, stripped the fill bolt, and i ordered another one.
anyway, I read some more on here about transmission fluid, and found that my transmission might not like new fluid, and i'm better off sticking with whats in there. i have 102000 miles on the car. and im wondering if changing the fluid is a good idea or bad idea.
ALSO, just a side note, when im shifting to second or third gear, the clutch or transmission or something sqeaks. almost like a small tire squeal... except its not the tires. idk, just looking for some input.
Thanks
Old Jul 27, 2007 | 04:32 AM
that_guy5's Avatar
Default RE: MT Fluid: to change or not to change
change all your fluids when you have to and it will save u in the long run
Old Jul 27, 2007 | 10:32 AM
ic892003's Avatar
jus get some genuuine honda tranny fluid and i has the same problem a few months a go, i stripped the filler bolt, i went toan exhaust shop that welds, i had them weld the same size bolt onto the filler bolt, then have them use a socket wrench to take it out, it works so jus do that, maybe that will solve ur squeaking problem
Old Jul 27, 2007 | 11:13 AM
s2000gtx's Avatar
why is there 2 of this topic
https://www.hondacivicforum.com/m_45.../tm.htm#458988
Old Jul 27, 2007 | 12:07 PM
mill$civic's Avatar
Good point. Locked.
pippo
Jun 16, 2014 12:08 PM
enigma34
May 13, 2009 06:41 PM
iwishiwasemo89
16
Jul 27, 2007 12:27 PM
Toppers
Feb 2, 2006 01:30 PM
induction1
Oct 22, 2004 01:01 AM
