need some help
Old Oct 23, 2007 | 02:40 PM
lew1's Avatar
Default need some help
hi just wanting 2 know a couple of things 1st things 1st i am really interested in boosting my 1.6 (d16z6) but just wanting 2 know if u would consider a engine rebuild it has 75000 on the clock ,which i know is not a lot 4 a honda but i understand the extrapresure a turbo adds. and also i am not wanting massive amounts of power (not just yet anyway ha ha ) so would it b possible 2 run with the standard injectors or would they still need uprating thanks
Old Oct 23, 2007 | 02:55 PM
Default RE: need some help
you're definitely going to want to upgrade the injectors. You'd have to run next-to-no boost to safely keep the stock injectors (as far as I know, anyway). And go to autozone and rent a compression tester. It's like a $30 deposit, and you get it all back when you return the tester. If your cylinders are within 10% of each other, you're good to turbo it.
Old Oct 23, 2007 | 08:12 PM
t34me's Avatar
if your planning on running more boost later, just build it while you have the block apart anyways
Old Oct 24, 2007 | 02:16 AM
lew1's Avatar
wel i was hopeing that i could boost without taking the block out ? this is possible isnt it most of the partsu canjust bolt on without removing the engine? its just that i ant got a massive bugget and am trying 2 keep cost 2 as low as possiblethanks
boobeyes
Jan 20, 2012 12:51 PM
PineappleMan
Feb 24, 2010 03:38 PM
joelmatt89
Jan 26, 2009 06:08 PM
dfdon
Aug 15, 2007 03:39 PM
CivicCrazy
Nov 29, 2004 11:50 AM
