What the h*** is going on
Old Oct 24, 2007 | 03:12 AM
93sir's Avatar
Default What the h*** is going on
So Sunday i put my DSM injectors w/resistor pack a\on my car and hooked up my hondata s300...Started the car and it ran rough.....So i started looking whats wrong...Took my #4 cable on my spark off and its fine took all the spark plugs out and they are all black except the #4 cylinder its almost like brand new....So what it looks like is that im running on 3 cylinders..how could this be...When the car is running and i disconect my plug wire the motor sound doesnt change at all....Could this be that my injector is bad or maybe resistor box....Before i hooked up s300 and injectors the car worked fine.....
Old Oct 24, 2007 | 07:45 AM
Mr Mobsta Man's Avatar
Default RE: What the h*** is going on
Hondata does not work well with dsm injectors.
Old Oct 24, 2007 | 08:13 AM
riceburner700's Avatar
try cleanign the contact inside the dizzy, i had the same thing happen when i swapped the 8valve to the 16 valve, the car sounded like a sti, no joke and it was only running onthree cylinders, try leaning it out a tad bit
Hondata doesnt like dsm injectors as stated above, if you can maybe find some rc's
blkwidow
Jul 27, 2006 03:03 PM
JohnHenry
Jan 26, 2005 02:40 AM
bills99si
Jun 25, 2004 05:48 AM
jclaunch
May 19, 2004 04:06 AM
