what transmission fluid to use
Old Nov 6, 2007 | 09:21 AM
Default what transmission fluid to use
i have a 5th gen automatic, and have noticed that some of you guys use 10W-30 oil in the transmission. Is this okay for automatics, or do I stick with transmission fluid. Also, when i change it, what type of fluid should i use
Old Nov 6, 2007 | 09:38 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: what transmission fluid to use
I have a manual 5th gen and I only use genuine honda trans fluid (it's just fantsy synthetic fluid)
Old Nov 6, 2007 | 11:58 AM
Alright, is the fluid the same for both transmissions? And if not, what is the difference between automatic transmission fluid and what you would use on a manual. Also, my Haynes manual says i should use Dexron II automatic transmission fluid; anyone have anyobjections to using this?
pippo
Jun 16, 2014 12:08 PM
kdubbla
Jul 23, 2009 06:54 PM
DannyHC
Jun 18, 2009 08:48 AM
enigma34
May 13, 2009 06:41 PM
civicblend97
Feb 19, 2007 06:13 PM
