Underdrive pulley keyway problems
Old Jan 28, 2008 | 07:48 AM
HaZe89's Avatar
Default Underdrive pulley keyway problems
Hey i just buy and lightweight underdrive pulley, when installing i realize that the key that goes in the keyway is bigger than the pulley's keyway, can i grind it or do something to make the key fits there?????
Old Jan 28, 2008 | 09:20 AM
importcivicus's Avatar
Default RE: Underdrive pulley keyway problems
are you sure you order the right part for your car. and learn how to speak.
Old Jan 28, 2008 | 01:44 PM
didder's Avatar
leave your stock pulley on... its called a "harmonic balancer" because it "HARMONIOUSLY BALANCES" Lol?? notice the rubber inside the pulley? that keeps everything from vibrating out of control
you are better off selling that little p.o.s. on ebay again and buying a mod somewhere else
just my 2cents
Old Jan 28, 2008 | 01:51 PM
Mr Mobsta Man's Avatar
Yea if you are talking about the crank pully then throw it on ebay because it will eventually be the death of your engine.
Old Jan 28, 2008 | 09:30 PM
HaZe89's Avatar
is not that bad the keyway fist but its tight i think about grinding it a bit so it will fit not too loose not too tight
Old Jan 28, 2008 | 10:09 PM
polo708's Avatar
are you serious??
it wont be balanced if you "grind" it and your motor will be laughing at you in the near future as you are sitting on the side of the road. Pulleys are the absolute worst mod for an econo 4-cylinder motor. Take the above advice and buy a different mod if you are looking for power... it will be the most expensive 2hp increase you will ever pay for.
Old Jul 28, 2009 | 07:55 PM
Originally Posted by Brandon Paul
Don't even attempt to grind it man. Are there any warranties for that one or you just bought it somewhere else? Well, performance pulleys are essential parts of the engine. So whenever you have doubts, hire a local car mechanic to fix things out.
Dude, stop replying to dead threads.
EDIT: Oh, I see now, you're spamming. Hope you enjoyed your stay while it lasted...
davidjcomeaux
Aug 12, 2008 07:57 PM
hondaimports30
Sep 21, 2006 02:04 PM
Jezzro
Jul 10, 2006 09:47 PM
gotcivic2007
Mar 12, 2006 12:16 PM
02CivicEX
Feb 1, 2005 06:34 PM
