Installing Tweeters..
Old Feb 21, 2008 | 02:58 PM
tarheels131's Avatar
Default Installing Tweeters..
Ok, so my current set up in my 99 civic ex coupe is..... 2 memphis 6.5"s in the bottom of the doors, 2 memphis 6x9's in the rear dash, an alpine 12" sub in the trunk and a kenwood amp feeding from the sub... Also, the kid that had the car before me bought 2 tweeters (one for each door by the window) but never hooked them up.. I have a Sony xplod CDX-MP70 head unit and here is the guide to the wiring:
- blue with white stripe = amp trigger
- white = left front (+)
- white with black stripe = left front (-)
- gray = right front (+)
- gray with black stripe = right front (-)
- green = left rear (+)
- green with black stripe = left rear (-)
- purple = right rear (+)
- purple with black stripe = right rear (-)
- yellow = hot always
- red = hot when key switch is on
- light blue = attenuate input (cell phone, etc.)
- blue = antenna trigger
- black = ground
Now how about would i go hooking up those tweeters?!
Old Feb 21, 2008 | 03:08 PM
95civic1.6l's Avatar
Default RE: Installing Tweeters..
when you put in the front door speakers. There should be 2 wires that go from those sets of wires up to the tweeter.
Old Feb 21, 2008 | 06:11 PM
sde780's Avatar
I'm curious as to where you mount these, my 98 sedan doesn't come with mounting locations, is there an A-pillar thing you can buy?
Old Feb 21, 2008 | 06:26 PM
bakertime's Avatar
Good to know, I've got two tweeters not hooked up to anything also.
You can really put them wherever you want.
Old Feb 21, 2008 | 06:41 PM
they mount where your mirror connects to the car. THere is a little plastic triangle on each side that they would mount into it they were stock but im not sure if they will fit aftermarket ones unless you mount them to the outside of them
Kov
Oct 12, 2006 05:18 PM
Scroder
Aug 26, 2006 02:37 PM
GlennS
Mar 14, 2006 01:29 AM
chones2083
Aug 7, 2005 01:19 PM
berto_14
Jul 26, 2005 02:44 PM
