95 coupe.. drop amount on 17s
Old Mar 20, 2008 | 11:12 AM
RyanEJ2's Avatar
Default 95 coupe.. drop amount on 17s
How much can u drop a 95 ej2 coupe on 17s? Anybody know?
Old Mar 20, 2008 | 11:20 AM
Default RE: 95 coupe.. drop amount on 17s
a lot
But for real, do you know the offset of your 17's? I'm assuming they're 17x7's and you're running 205/40-17 tires? If the offset is higher than +38mm and you're running the right size tires, you can lower it as much as you want without rubbing (except the front... you really can't tuck too much tire in front without it rubbing around slow turns)
Old Mar 20, 2008 | 11:24 AM
RyanEJ2's Avatar
that looks awesome! I wanna drop but not sure how much.. would i be able to go like 50mm all round with no trouble, yeh that is my wheel tyre set up by the way, i dunno about the offset tho.
Old Mar 20, 2008 | 11:39 AM
your offset is really what will determine whether or not you'll have problems when you lower it. If it's a big enough offset, you'll be fine with any amount of lowering (within reason). If you're willing to pull off one of your wheels, the offset is usually stamped on the back of one of the spokes.
Old Mar 20, 2008 | 11:56 AM
RyanEJ2's Avatar
ah ok awesome, well its pitch black now.. ** goes to get torch. **
Old Mar 20, 2008 | 12:09 PM
RyanEJ2's Avatar
all they said was 4x100, 4x114.3 and then like stuff in kg etc dunno if that helps?
Old Mar 20, 2008 | 02:08 PM
civicexracer's Avatar
it should say somewhere something likr "ET:.." then some number. then number is r offset.
Old Mar 20, 2008 | 02:37 PM
RyanEJ2's Avatar
ok and this will be on the INSIDE of one of the spokes??
Old Mar 20, 2008 | 02:45 PM
yeah, it should be stamped on the inside of one of the spokes.
addiction2bass
22
Jun 21, 2007 08:16 AM
Motor35
Oct 6, 2006 11:13 PM
Matty Civics
Sep 11, 2005 04:56 PM
crxguy89
Mar 23, 2005 02:22 PM
02CivicEX
Mar 6, 2005 10:45 AM
