reset ECU, but CEL comes right back on!
Old Apr 9, 2008 | 12:39 PM
imshirazy's Avatar
Default reset ECU, but CEL comes right back on!
I don't know what the crap is up. I failed emissions a little over a month ago and am therefore trying to fix the issue...
I just replaced my primary oxygen sensor, then when I went to go reset the ECU, the CEL came back on not within miles, but within seconds!
What does this mean??
I checked the code and the light blinked 6 slow times and 5 regular, but I can't find the chart anywhere that tells you what each number means. Even if it was anything bad, shouldn't that light not come on for X amount of miles?
Old Apr 9, 2008 | 01:16 PM
Default RE: reset ECU, but CEL comes right back on!
65
Accord Civic CRV CRX Del Sol Odyssey Prelude
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
[&:] maybe your secondary sensor
Old Apr 9, 2008 | 01:18 PM
Code 65 indicates a problem with the heater element of the secondary O2 sensor (after the cat). The CEL turns ON immediately because the fault with the O2 heater circuit is sensed rapidly by the ECU. Replace the sensor.
Old Apr 9, 2008 | 01:39 PM
imshirazy's Avatar
Ok bought it, will install tomorrow...
I really need to pass emissions soon, my time is running out
Old Apr 9, 2008 | 04:56 PM
danomatic93's Avatar
June 2010 ROTM
depending on your local laws, there might be a dollar amount of fixed/replaced parts, that allows you to be exept for that years test. In Wisconsin, if you exceed 500 or 600 dollars in attempts to pass emissions, they let you go for the next two years.
Old Apr 9, 2008 | 07:44 PM
imshirazy's Avatar
I heard it was 300 but i can't find the rule anywhere :/
Old Apr 9, 2008 | 08:08 PM
cyberx32's Avatar
I dont think its gonna be 300 cause most of the emmission stuff costs a lot
Old Apr 10, 2008 | 09:28 AM
imshirazy's Avatar
replaced the back one and now it's going ok, lets see how long before it comes on again lol
Old Apr 10, 2008 | 09:35 AM
June 2010 ROTM
crossed fingers
mrtimepa
Jun 20, 2013 08:33 AM
Lunatic1
Apr 19, 2011 03:40 AM
wookieneck
Jan 6, 2009 06:38 AM
denisholden
Nov 25, 2007 07:56 PM
Auto98EX
Sep 25, 2005 01:41 PM
