clutch master cylinder
Old Jun 2, 2008 | 09:37 AM
blackmetal619's Avatar
Default clutch master cylinder
ok so yesterday I changed the slave cylinder no problem, but when I go to do the master cylinder, I cant remove the pin thats holding the screw in. Its on the inside of the car connected to the clutch pedal.
How do you remove this pin?
its such a tight fit back there I cant see which way to pull it out
Old Jun 2, 2008 | 10:43 AM
Default RE: clutch master cylinder
Helpful Hint: Include the year and model of your Civic in your signature.
You must first remove the cotter pin. This information should help:
Old Jun 2, 2008 | 11:59 AM
thanks, i finally got it.
VXHatchHero
Jun 13, 2010 09:42 AM
saturn78
Apr 19, 2007 01:36 AM
sway2003
Dec 27, 2006 07:33 PM
Dogmeat
Feb 3, 2006 10:38 PM
jcclow
Jan 21, 2005 09:36 PM
