Code p0131?
Old Jun 28, 2008 | 01:31 PM
Jeremy102579's Avatar
Default Code p0131?
gota CEL today, scanned it and got a code here:
p0131 - o2 sensor circuit low volts bank 1 sensor 1
is the sensor bad, how many o2 sensors do i have and where should this one be located?
2000 ex coupe 5-speed 87,000 miles.
Old Jun 28, 2008 | 01:37 PM
Default RE: Code p0131?
Your Civic has two O2 sensors, primary (before cat) and secondary (after cat). The code is for the primary O2 sensor, which is most likely bad. It might also be a problem with the O2 sensor circuit. You can troubleshoot the problem as described in the 96-00 Civic manual found in the link in my signature.
Old Jun 28, 2008 | 04:46 PM
ok, now i see they have them at www.napaonline.com for like $77 universal sensors...are these ok?
or should i get the more expensive ones?
any advice is greatly appreciated?
Old Jun 28, 2008 | 10:48 PM
First clear the CEL code from the ECU by removing the 7.5A BACKUP fuse under the hood for 30 seconds. Reinsert fuse and drive the car. Don't take any action unless the CEL code for the O2 sensor returns.
Personally, I would avoid a universal O2 sensor because I think you must solder wires for installation. I would purchase a sensor with a proper connector that allows easy installation.
Old Jun 29, 2008 | 07:20 AM
ok, i removed the fuse for 30 seconds and reinstalled it. now the light is off.
also, i need to reenter the code for my radio, where do i fin the code at for the radio?
Old Jun 29, 2008 | 07:51 AM
Hopefully, you have the anti-theft code stored somewhere. Have you checked the glove box and your owner's manual? Otherwise, you may need to call your Honda dealer.
Old Jun 29, 2008 | 07:59 AM
my car never came with the code card with the 5 digit number on it.
this code is 5 digits right? and is it only located on a card?
i dotn know the serial number for the system either, where would i find that at?
Old Jun 29, 2008 | 08:08 AM
ORIGINAL: Jeremy102579
I have a 97 Civic that doesn't require a radio code so I don't have answers to your questions. Perhaps other members can help you with this problem.
Old Jun 30, 2008 | 09:43 PM
ok, went to the dealer today with the serial number and the guy printed out a copy of the code # for me so that is all good.
the light has not come back on since after putting 20+ miles on car.
what may have caused it to go on in the first place and not again?
Old Jul 1, 2008 | 05:49 AM
mundy5's Avatar
jeremy, check the back of your ash tray or a storage tray. my wife's former accord had the stereo code stored there.
it could very well be a faulty o2 sensor that is tripping your codes. 20 miles is a bit premature to declare victory over this issue. i'd give it another few weeks..
brutiarti
Dec 7, 2011 03:55 PM
civic99whistler
Dec 10, 2008 09:56 AM
rok_spitfighter
Mar 2, 2008 10:12 AM
laddylam
Jan 9, 2008 06:01 PM
Black Magician Hiro
Jan 15, 2005 08:47 PM
