cant hold idle
Old Jul 15, 2008 | 07:15 PM
o320's Avatar
Default cant hold idle
i own a civic 00 ex and my problem is when i come to a stop my car idle drops till it dies. its worst if i come to a sudden/fast stop. i do have a bad o2 sensor, oculd that be the problem?
Old Jul 15, 2008 | 07:29 PM
Default RE: cant hold idle
Well first off, fix the problem causing the O2 sensor code. This critical sensor optimizes the air/fuel ratio to give the engine the best performance and gas mileage. You also risk rapidly destroying the cat if the O2 sensor isn't working.
Regarding the idle problem, try retrieving possible CEL trouble codes from the ECU (see link in my signature) and also try cleaning the IACV on the throttle body (see forum DIY).
Old Jul 15, 2008 | 07:36 PM
ej6buddy's Avatar
make sure you find out which o2 sensor is the problem, chances are, it's the primary that usually fails, and then go from there, no need to clean the IACV and take a chance that he might mess something up in the process. (that is if he's not mechanically inclined)
Old Jul 17, 2008 | 05:33 PM
jermofrejected's Avatar
well if you got a bad o2 sensor might as well replace it that will prabably help. my buddies 88 accord did that. he would brake it would die. his had a carburettor tho but he found out that he had a vacuum problem he fixed that and it went quit dying
Old Jul 18, 2008 | 09:31 AM
biocpu's Avatar
How do we diagnose that o2 sensor has failed or failing? I have a similar problem with civic DX 2001.
Old Jul 18, 2008 | 09:35 AM
Generally by a CEL trouble code indicating a problem with an O2 sensor. Otherwise, you'd need a good scan tool.
whitworthsean
Nov 8, 2007 09:22 PM
mill$civic
Jun 16, 2006 10:14 PM
civicxtreme
May 15, 2006 08:11 PM
fast93civic
Dec 21, 2004 07:59 AM
Rice Tumbler
Aug 11, 2004 09:06 PM
