A/C problem!!
Old Jul 21, 2008 | 07:10 PM
millsee's Avatar
Default A/C problem!!
Hi, This is my first post on this site. I have an A/C or fan problem with my 2002 civic. I was driving normally and the air and fan just shut off, like a fuse went. I checked the fuses and all are ok. If i start the car and turn on the air, the fan will come on for a few seconds and switch off. This only happens the first time you try to turn it on, after that nothing. Any ideas?? Dont want to take it to the dealer and spens big bucks.
Old Jul 22, 2008 | 09:00 AM
Default RE: A/C problem!!
Try to retrieve a trouble code:
Old Jul 22, 2008 | 09:02 AM
Does the radiator fan run? Does the compressor clutch engage?
Old Jul 23, 2008 | 04:47 PM
I8UMUP's Avatar
didyou just recharge the system? if so it may be locking out on high head pressure due to haveing to much freon in the system
Old Jul 23, 2008 | 08:12 PM
millsee's Avatar
I got a code 12 doing the self diagnosis. I believe it means the power transistor module is gone. Also there has been bits of filter coming out of my vents. I will check both and see what happens. Thank you very much for your help.
Old Jul 23, 2008 | 08:16 PM
RiseAgain97's Avatar
hmmm code 12?? isnt that an obd1 code?
an obd2 code should be P1234 something in that order
Old Jul 23, 2008 | 08:22 PM
ORIGINAL: RiseAgain97
The OBD/CEL trouble code system is different from the HVAC trouble code system.
Slammed98silvercoupe
14
Dec 19, 2010 05:16 PM
djt
Jun 21, 2008 07:48 AM
redlines4us
Aug 22, 2006 05:49 AM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
