tons of b18a1 rebuild questions
Old Oct 10, 2008 | 12:09 PM
soafed's Avatar
Banned
Default tons of b18a1 rebuild questions
* First can i use any other b-series cams in a b18a1
* Where can i find a good rebuild guide
* Are the pistons from ebay or perfectengines.com reliable
* How much drop should i get form the ebay coilovers
* Anyone no a good place to find fairly cheap rims
* can i use any other b-series pistons in b18a1 to raise compression
* Where can i find aftermarket piston rings and will they help with nitrous reliability, with good tune and rare use.
* Anyone one recommend a specific oil for when i put the motor back together.
* Should i run synthetic oil after rebuild.
* Will a haynes manual have the torque specs for the motor.
* Can i use a b16 tranny on this motor. i no it has the shorter gears.
* Will a msd ignition box, blaster coil, msd plug wires, 320cc injectors, AEM fuel rail and regulator help with nitrous reliability. Friend offered good deal on them.
* Anything you would recommend to replace besides gaskets, all bearings, and piston rings.
* I'm getting my head and block resurfaced and honed anyone recommend any other machining work.
Old Oct 13, 2008 | 06:11 AM
soafed's Avatar
Banned
come on guys help me out
Old Oct 13, 2008 | 07:15 AM
bcivic's Avatar
How about what are you trying to build for? Sounds like you want it to be quick NA and then run some spray. If you want a decent bump in horsepower a b16a head on that block would great. Yes you can use a b16a tranny get one with the same clutch Im guessing you have a cable clutch so get a cable clutch tranny. msd igninition stuff is not necessary injectors arent a bad idea if you really want to run nitrous. Get a haynes manual without a doubt and it does have all the torque specs.
Old Oct 13, 2008 | 01:02 PM
315 Customs's Avatar
you can use any non-vtec cams
any auto parts store - haynes or helms
depends what you are building the motor for and ebay doesnt make pistons so you have to be a little more specific
again ebay isnt a company so provide a link or some brand of coilovers
eBay
any piston made for a b series engine will work in a b series engine
google it, and look for either forged pistons or titanium pistons and the proper rings will be included with them
many many different theories on this. I used conventional oil for the first 500 mile break in, then full synthetic oil after that
I say yes but again many different theories on this
yes
yes you just need a cable tranny if thats what you have now or a hydraulic tranny if thats what you have but any b series tranny will work
MSD helps but stock ignition can handle close to 400hp. Injectors are a good idea for running nitrous but you need to get something to tune with (Hondata, AEM, Chrome, etc)
water pump and timing belt!!!!!
sounds good
hoped that helped ya
McLovin
Jun 10, 2009 02:44 PM
immaN00b
24
Jun 6, 2008 12:12 PM
F23AccordLX
EG Swaps
Feb 23, 2006 09:41 PM
cpuma00811
Jul 27, 2005 02:24 PM
polo708
Jun 11, 2004 01:06 PM
