WHAT IS V-TEC E ? ? ? ? ?
Old Jul 6, 2005 | 12:56 AM
smokingemcee's Avatar
Default WHAT IS V-TEC E ? ? ? ? ?
Ok, I met this chick who drives a 93 hb civc vx, and I thought only si and ex civics had vtec. I popped her hood and the valve cover read V-TEC E? It also had a V-TEC selinoid. What the heck is V-TEC E? It also had a ridiculously small throttle body, which makes me this it's an hf motor. . .
Old Jul 6, 2005 | 01:12 AM
LEVIII's Avatar
Default RE: WHAT IS V-TEC E ? ? ? ? ?
it is a real gas saver vtec that just uses the vtec to swirl the air and get an almost perfect combustion. It is deff not performance oreinted. It is an awesome awesome gas saver though.
Old Jul 10, 2005 | 06:21 PM
Kappa22's Avatar
VTEC-Economy...
Old Jul 11, 2005 | 12:48 AM
I knew that E stood for economy. . . . . .
Old Jul 14, 2005 | 09:04 AM
Hendog24's Avatar
(I Found this)
VTEC-E is a twist on the regular VTEC mechanism. Whereas VTEC's purpose can be more or less summarized as: extracting high RPM performance while maintaining smooth low RPM operation, VTEC-E can be summarized as: allow extremely lean fuel-air mixture at low RPMs in order to increase fuel economy. In other words, VTEC technology is used to optimize different ends of the RPM range in the two different implementations.
Old Jul 14, 2005 | 04:13 PM
skytanker2003's Avatar
Asked the same question and Omen68 was kind enough to get me the entire history!!! Hope it helps!
HondaEGcoupe
Aug 9, 2009 10:12 AM
Kenneth Ames
20
Feb 17, 2007 10:39 AM
AOL.COM
Apr 24, 2005 12:07 AM
hondabboy
Jan 10, 2005 09:58 PM
89hatch
Dec 19, 2004 03:06 PM
