wierd noise
Old Dec 17, 2008 | 12:53 PM
rs634158's Avatar
Default wierd noise
I have a 97' coupe, I've noticed in the past month that when I make right turns there is an odd noise. At first I thought it was due to the new tires but the noise has not stopped and these tires have been on for a few month now. Has anyone had a similar problem? Any advise is appreciated.
Old Dec 17, 2008 | 01:05 PM
munkeewrench23's Avatar
i would check your struts and axels..
Old Dec 18, 2008 | 06:40 PM
conceptualpolymer's Avatar
What kind of noise is it? If it's clicking, your CV boot is probably leaking grease and the joint will need to be replaced. Also check the tires for wear on the inside. They might be rubbing on the fender or suspension part.
Old Dec 20, 2008 | 10:36 PM
rs634158's Avatar
yeah i originally assumed mayb it was the axles but i had both front axles replaced a little over a year ago.
Old Dec 21, 2008 | 05:30 PM
Okay, so what kind of noise is it? Are the new tires the same size the old ones?
Old Dec 23, 2008 | 08:47 AM
rs634158's Avatar
I had my mechanic take a look he said i need a new front hub bearing. He told me it would be $100 for the part plus 2 hours of labor and a charge for the pressing and it would run me $340. Any advise? the price seems like a lot of money.
Old Dec 23, 2008 | 08:57 AM
Marty's Avatar
check your vtec fluid
Justin13
Dec 29, 2008 10:01 PM
rs634158
Aug 8, 2008 07:33 PM
yoshithemonk
Jan 11, 2008 11:51 PM
DaRKoN
Mar 28, 2007 08:50 PM
carlover
Aug 2, 2005 10:07 PM
